- 16 Jun 2009
- Bucks
When I got my current car, the driver's side front tyre on my car was worn down in a band on the inner edge - and the steering arm on that side was bent (a little).
The tracking was out, as expected, now corrected.
I now want to check the camber. As I understand it, incorrect camber can also cause that kind of wear pattern.
The camber for my car is supposed to be this: -0 °34’ ± 45’ (-0.57° ± 0.75°)
I hung a plumb bob in front of the wheels and (roughly) measured the difference from vertical, between top and bottom of the rim.
Passenger side, the difference is less than 1mm.
Driver side, it looks like 5mm or so. The top is further in than the bottom ie negative camber, and that would agree with the wear pattern, I guess.
Can someone work out what the camber angle is from a 5mm difference top to bottom on a 15" wheel?
