Camcorder or Gopro
30 Dec 2009
Wigan Lancs
I'm going on holiday soon and want to take some video recordings while there,I'm won't be doing any sports or adventure stuff generally so not sure if a GoPro will be a good choice. Been looking at some 4K camcorders though.
What would you recommend please.
Yeah if you're not using a GoPro for what it's made for then it's not the right choice imo. For it's purpose, nothing really comes close to it sub £800.
If you're just using it to document your holiday then yeah you probably wanna go for a camcorder. Budget?
