Came across another partition while defragging...
8 Dec 2004
Hampshire
So when I click defrag in W7... it takes a little while to load up ... and when it does I get 3 drives...
C:
D:
and \\?\Volume{6f52a3f0-c406-11de-beaf-beaf-806e6f6e6963}\
I have no clue what that last one is.. I thought it was the USB port on my printer which is connected via LAN (but I have that turned off atm and that drive is still there...
Can anyone offer any comments or opinions about this? Cheers.
Yea I thought that too, but I dont see it come up on my computer (presumably) its hidden).
Also it seems to take a good 10 seconds to load up defrag. Is this normal?
It's a hidden partition with no drive letter so it's normal that it doesn't show up under My Computer. It isn't however normal for defrag to take 10 seconds to load, it's pretty much instant on my machine.
See Im concerned about the load time for defrag...
Could you tell me if that volume partition on your HD is similarly labelled like mine above?
It is.
Uncanny... I click mine and it takes more than 9 seconds...
Could this be a problem? Can I ask what HD you have and the size?
Also I was told there is a HD bench util in W7... do you know about it?
I checked mine, pretty instant when I load the defrag program & I dont have that partition on either of my drives.
Why would it forget to hide it thought.
And does anyone have any theories about why defray could be taking soon to load? Cause for concern?
Well, it can be system reserved partition from Vista or some other install, thus it doesn't have the name mapping in registry.
And no, you should not think about slow load of defrag tool.
Thanks a lot for your replies also faugusztin (and everyone).
Any theories why it would load slowly? In the back of my mind I am a bit peeved at this.
Also can I ask what HDs you have ?
