Camera Card Reader
7 Jul 2007
Mainboard Asus P5L VM, intel E6420 core 2 duo, Vista premium 64 bit 2 gig ram, 250 gb sata drive geforce 8600 gt vid card.
My camera card reader which was included with my computer when bought new 6 weeks ago has apparently stopped working, tho I must admit I have not used it in about a month and as case is at ground level I never noticed that power light on cardreader was not on. I don't know the name of the card reader. I've had the card reader out to check for a name but there is none except for a barcode number. I do not recognise any names in the device manager which might point to the card reader. So I do not know which driver to look for. In Widows Explorer Only C:drive, Dvd:/ and CD:/ drives are visible. All other USB devices are working normally and cable connections inside the case are checked and firmly connected.
I downloaded a generic driver from Driverguide but am not sure whether to install it in case it causes further problems cos is say's os's 98 upwards to Win2K.
Anything else I can check before taking it back to the shop.
Many Thanks
