I'm starting to look for a new/used camera to buy, primarily to be used on motorbike trips - so size is a big factor - and also will be used for some video.
A used EOS M with the 18-55mm kit len can be picked up for £150-180, another possibility is the Canon 100D but these are £200+ for the body only.
I used to have a Nikon D70 quite a few years ago I'm well versed in 'proper' photography (was the main photographer at my sisters wedding), so a simple p&s with no manual modes would be extremely annoying to use!
Any other suggestions for around £200-250 max? Seems like the EOS M is a bit of a bargain, even if the focus is a little slow (not that important for what will be 90% landscape shots). Not looking to spend a huge amount as it won't get that much use outside of travel use, maybe 4-5 trips per year plus some general use.
