I built a pc for a friend a little over a year ago, a i7-4770K @ 4.3ghz with H100i. It used to max out at 85c when encoding (less when gaming) for the year he has had it and suddenly in the last couple of weeks it has jumped from 85c max to hitting 100c and throttling.
I got him to remove the heatsink and reapply some mx4 which made no difference, I think it's probably the pump that is causing the issue although the pump is reporting an rpm in the corsair software so appears to be running.
Is there any chance that the cpu could have degraded and that's why the temps have shot up? I have heard of cpu's degrading with too much voltage (which this one didn't have) causing them to die or becoming unstable but never the temps shooting up?
