- 15 Apr 2020
Ok, so I have a gpu that says it can output 4 monitors.
I have set it up with 3 monitors 2 matching and one odd one I had left over from the upgrade.
For some reason if i use3 monitors for desktop or full stretched gaming my gpu will shut down and the fans will go to idle and it doesnt reset and all monitors say no signal.
Then to fix the issues i have to unplug the odd monitor and delete the drivers for the gpu via device manager then the 2 matching monitors will work perfectly so can a faulty monitor or connection lead cause the gpu to crash?
Also i noticed when using msi afterburner the gpu temp went up to 50°c when just starting a game.
Hope some one has an answer.
The gpu is the RX 570 nitro+ 8GB.
Cheers
Cheers
