The PSU i'm using is http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-OK&groupid=701&catid=123&subcat=1709
I've had supposed "good quality" PSUs fail in the past amd this one has worked brilliantly.
The trouble is, my new gtx 670 arrived and it has a 6 pin and an 8 pin. My 560ti ran on 2 6 pins and power consumption on the 670 isnt mcuh higher so i thought it would be fine.
Anyway, i plugged the card in on 2 6 pins and it seems to be working fine. I don't like using the 8 pin adapter as i once destroyed a card when i used those.
So since my PC has botted to windows fine and GPU-Z shows all ok, is it ok to run the card on 2 6 pins? Or is a 6 and 8 required?
How can i find out if the card is getting enough juice?
