- 4 Dec 2012
- Bournemouth
Strange one I've been asked by a friend that I've not been able to find a conclusive answer for after some searching. He's got a fairly old machine and using a GTX1080. He's picked up a new Alienware monitor that's capable of 360hz, however he's only getting the option for 240hz on all of the resolution options he has in the Nvida control panel. It's looking like the 30 series bring in support for 360hz but in other places it says that DP1.4 should be all you need, which the GTX1080 can do (after a firmware update that is!).
I have a 3080 we could use to test this theory out, but he lives a few hours away so it's not worth doing. Wondering if anyone here ran into this issue where you monitor was 100x better than your GPU
Thanks all!
Thanks all!
