Why would that be cool?
Xbox VCR?I reckon you could easily do it in the Xbox VCR
Original Xbox One, before the slim came out.Xbox VCR?
I would love to.Cool idea, if you end up doing this please post some pics!
I am thinking of puting the GPU fans facing up with a cable riser if I do 1, Just can get a mITX tray and 2 slots online.This was a build from the original Xbox but I was and still am impressed with the build: https://www.reddit.com/r/buildapc/comments/11vzkk/guy_builds_pc_linux_and_mac_computer_in_xbox_os/
I'm sure there are better looking "objects" than xbox caseI think it would be so cool.
The Xbox has a height of 3.58” (91 mm), width of 12.6” (320 mm), depth of 10.2” (259.1 mm)
Would need a Powerbrick
I very much like the Velka 7, it would be perfect if it was a little deeper, it is odd the way the GPU goes in that.I'm sure there are better looking "objects" than xbox case![]()
