Was fitting up my new Stacker 810 today and had no trouble with a Seasonic S12 600W although the fan is partially obscured by the ledge above.
Are you quite mad?
You'll get too close and..BAM...entrails all over the wallpaper behind your case! Id recommend fitting 3 of the modules and swap all the fans in the case for something like the Vantec Stealth, using gel gaskets where possible. I'm finding them almost silent.
badbob said:Should I replace all those fans with Delta Crossflows? (and get two more 4 in 1 modules)Will my cat get sucked into my front vents
Are you quite mad?
