Hello ,
Im very new to the wirless thing but i managed to set up my own network at home with great ease ( pat's self on back
The thing is i have had to move both my PC's in to one room for a short time so i decided to just connect to the net with one PC via a router and im using a USB network adapter on the other PC .
As the 2 PC's are in the same room i thoght i would just sit the USB adapter on top of the router thus giving me a tidy room and a strong 100 % connection ... this work's ok ..but..
I have noticed over the last 2 or 3 days i seem to be getting a lot ofheadaches and it got me thinking about how the radio waves affect you at close range ?
The hard wired router is sitting right in front of me and the USB adapter is sitting right on top of the router ... so with the signal not having to travel far , Is it possible that the extra siglan may be causing me headaches ?
If anyone has an answer to this i would appriciate it , If anyone can tell me a way to maybe turn the signal down i would appriciate that too .
Am i just being silly ?
/ sitting here witha tin foil hat on head
)The thing is i have had to move both my PC's in to one room for a short time so i decided to just connect to the net with one PC via a router and im using a USB network adapter on the other PC .
