help please, im not qutite sure what the problem is but i'll explain it; ok ive rebooted a pc but when try to install the drivers and utility disc, my drive couldnt read anything at all but i can read it on another pc, so i copied the content from the cd to my ipod. when installing drivers from the ipod everything seemed fine but when i tried to to go to control panel-system the window will appear for a second and closes. and when i plugged my ipod, autoplays perfoms and then the pc shuts down and restart, after restart my taskbar and start menu has changed to a classic lookalike but not exactly, the my computer icon is blank and when i go to my computer-c:drive it shows the my picture my music folders and same thing goes to clicking on my ipod but i can use the folder directory onthe left to go to the files??? okay then sso i then tried to install latest update but then finishes with about 7 failed and restarted but this time window does start and would just keep restart over and over again?? sooo ist there any1 that can help me pleeeaase thaNKS.
