- 6 Jan 2024
- Londonderry
Bugcheck Analysis:
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) This is a very common BugCheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80232527749, The address that the exception occurred at
Arg3: ffffb700ca0a6878, Exception Record Address
Arg4: ffffb700ca0a6090, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.mSec
Value: 1343
Key : Analysis.Elapsed.mSec
Value: 1424
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 155
Key : Analysis.Init.Elapsed.mSec
Value: 2666
Key : Analysis.Memory.CommitPeak.Mb
Value: 111
Key : Bugcheck.Code.KiBugCheckData
Value: 0x7e
Key : Bugcheck.Code.LegacyAPI
Value: 0x7e
Key : Dump.Attributes.AsUlong
Value: 1800
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 100
Key : Failure.Bucket
Value: AV_nt!RtlSubtreePredecessor
Key : Failure.Hash
Value: {9c83f313-8194-6a8e-da2b-014e09f29178}
Key : Hypervisor.Enlightenments.ValueHex
Value: 1497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 4853999
Key : Hypervisor.Flags.ValueHex
Value: 4a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 3f7
Key : SecureKernel.HalpHvciEnabled
Value: 1
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Version
Value: 10.0.22621.1
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80232527749
BUGCHECK_P3: ffffb700ca0a6878
BUGCHECK_P4: ffffb700ca0a6090
FILE_IN_CAB: MEMORY.DMP
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1800
EXCEPTION_RECORD: ffffb700ca0a6878 -- (.exr 0xffffb700ca0a6878)
ExceptionAddress: fffff80232527749 (nt!RtlSubtreePredecessor+0x0000000000000009)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: ffffb700ca0a6090 -- (.cxr 0xffffb700ca0a6090)
rax=0040000000080000 rbx=ffff80030e569d78 rcx=ffff80030e569d78
rdx=ffffa20699c54ef0 rsi=ffffa20699c54ed0 rdi=ffffa20699c54ef0
rip=fffff80232527749 rsp=ffffb700ca0a6ab8 rbp=ffffffffffffffff
r8=ffffffffffffffff r9=7ffffffffffffffc r10=fffff802325264e0
r11=000000000000be50 r12=0000000000008000 r13=0000000000000000
r14=ffffa20699c54ef0 r15=0000000000000706
iopl=0 nv up ei pl nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050206
nt!RtlSubtreePredecessor+0x9:
fffff802`32527749 488b4810 mov rcx,qword ptr [rax+10h] ds:002b:00400000`00080010=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
READ_ADDRESS: ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffb700`ca0a6ab8 fffff802`32526594 : ffffffff`ffffffff fffff802`324ec884 00000000`00000000 ffff8003`0ed1d580 : nt!RtlSubtreePredecessor+0x9
ffffb700`ca0a6ac0 fffff802`30b6bbf4 : ffff8003`0e569d78 ffffa206`99c54ea8 ffff8003`0f0d5760 fffff802`30ba2f4b : nt!RtlDeleteNoSplay+0xb4
ffffb700`ca0a6af0 fffff802`30ba29dc : ffffa206`99c54ed0 00000000`00000000 ffff8003`0f0d5700 fffff802`3246a0f1 : FLTMGR!TreeUnlinkMulti+0xf4
ffffb700`ca0a6b40 fffff802`30ba3b3a : ffffa206`8d222010 ffffb700`ca0a6d00 ffff8003`0f0d5700 fffff802`3250cc40 : FLTMGR!CleanupStreamListCtrl+0xec
ffffb700`ca0a6bc0 fffff802`32898732 : ffff8003`0f0d5738 ffff8003`0f0d5700 ffff8003`0f0d5738 ffff8003`0f0d5700 : FLTMGR!DeleteStreamListCtrlCallback+0xba
ffffb700`ca0a6c00 fffff802`3757cfe0 : ffff8003`0f0d5700 ffffb700`ca0a6d48 ffffb700`ca0a70d0 00000000`00000705 : nt!FsRtlTeardownPerStreamContexts+0xe2
ffffb700`ca0a6c40 fffff802`3757c4c1 : ffff8003`0f0d55e0 ffff8003`00008000 ffff8001`01000000 00000000`00000000 : Ntfs!NtfsDeleteScb+0x170
ffffb700`ca0a6ce0 fffff802`3744730d : ffff8003`0f0d5700 ffff8003`0f0d5700 ffff8003`0f0d55a0 ffff8003`0f0d5700 : Ntfs!NtfsRemoveScb+0xad
ffffb700`ca0a6d40 fffff802`3757c210 : ffff8003`0f0d55a0 00000000`00000000 ffffb700`ca0a70d0 ffff8003`0f0d5700 : Ntfs!NtfsPrepareFcbForRemoval+0x5d
ffffb700`ca0a6d80 fffff802`37447012 : ffffb700`ca0a70d0 ffffa206`8d28f1b0 ffff8003`0f0d5a00 ffff8003`0f0d55a0 : Ntfs!NtfsTeardownStructures+0xa0
ffffb700`ca0a6e00 fffff802`3757b903 : ffffb700`ca0a6fc8 ffffb700`ca0a7480 ffffb700`ca0a6fc8 ffff8003`0f0d5500 : Ntfs!NtfsDecrementCloseCounts+0xe2
ffffb700`ca0a6e60 fffff802`3757b302 : ffffb700`ca0a70d0 ffff8003`0f0d5700 ffff8003`0f0d55a0 ffffa206`8d28f1b0 : Ntfs!NtfsCommonClose+0x423
ffffb700`ca0a6f30 fffff802`37555cf8 : ffffb700`ca0a7100 ffffa206`8d28f1b0 ffffb700`ca0a7480 ffffa206`8731fc00 : Ntfs!NtfsFspCloseInternal+0x252
ffffb700`ca0a7090 fffff802`32434f85 : ffffa206`8731fc00 ffffa206`996fa000 ffffa206`00000000 ffffa206`00000000 : Ntfs!NtfsFspClose+0x88
ffffb700`ca0a7380 fffff802`32507167 : ffffa206`996fa040 00000000`000006ae ffffa206`996fa040 fffff802`32434e30 : nt!ExpWorkerThread+0x155
ffffb700`ca0a7570 fffff802`3261bb94 : fffff802`2fbec180 ffffa206`996fa040 fffff802`32507110 aeac53f0`6b65f40a : nt!PspSystemThreadStartup+0x57
ffffb700`ca0a75c0 00000000`00000000 : ffffb700`ca0a8000 ffffb700`ca0a1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME: nt!RtlSubtreePredecessor+9
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
STACK_COMMAND: .cxr 0xffffb700ca0a6090 ; kb
BUCKET_ID_FUNC_OFFSET: 9
FAILURE_BUCKET_ID: AV_nt!RtlSubtreePredecessor
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {9c83f313-8194-6a8e-da2b-014e09f29178}
Followup: MachineOwner
Arguments:
Debugging Details:
Key : AV.Fault
Value: Read
Value: 1343
Value: 1424
Value: 0
Value: 0
Value: 0
Value: 155
Value: 2666
Value: 111
Value: 0x7e
Value: 0x7e
Value: 1800
Value: 1
Value: 0
Value: 100
Key : Failure.Hash
Value: 1497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 4853999
Value: 4a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 3f7
Value: 1
Key : WER.OS.Branch
Value: ni_release
Value: 10.0.22621.1
BUGCHECK_CODE: 7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME: Windows 10
