- 17 Sep 2006
hi,
I have a netgear router which my PC is wired to, in the last few days the small computers in the system tray have appeared with a red cross saying that the network cable has been unplugged, every so often it will connect again but for no longer than 30 seconds and it dissconnects again.
I have plugged my laptop into the same cable and it works fine the connection is fine and does not drop.
Im guessing theres a problem with my computer which is not allowing it to see the router im just not sure what settings to play with.
I have a intergrated lan card on my PC which is only a couple of months old
any ideas?
thanks
James
any ideas?
thanks
James
