Hey guys im running a script to install BGINFO..now im not too sure if its bginfo causing the problem or my bad coding
Basically everything works fine but the login script just gets stuck and doesnt go away?
here is a pic:
Why doesnt the script just flash off after running the script I have to manually click the x button..
FYI if I I take the /taskbar option out it runs the script and closes fine.
I basically need to know a command (if it exists) to close the window?
Thanks
here is a pic:
Thanks
		 / thanks very much
/ thanks very much
