Can anyone help me
13 Aug 2004
Hi all, I wonder if someone could help me out. I have a P182 case and cause of the length of my 7950 card I had to remove my middle drive cage and mount my 3 HDD's in the bottom cage. The problem is that the cage uses those screws with washers on the head and the longer thread.
I had to attach my HDD without the white gromits and use shorter screws, but the problem I got is that the drive is vibrating through the case when accessing stuff and it is worse now as I got really quiet fans.
I was wondering if anyone had some spare screws of that type * removed * as Antec dont seem to have them on their site. I know I can nick 1 screw from each of the other 2 drives, but would rather do it proper. Any help is appreciated. Thanks.
You can't sell or buy stuff outside of the MM unfortunately. I'd edit that out, that said, get in touch with Antec directly (customer services) they might be able to help, or at least tell you thread size and the such like.
A forum member might be able to tell you the thread type as well, they're often m3's in cases... But I can't guarantee it, which is why I'd recommend you ask antec themselves about the screw type.
kd
