Can anyone help with an asp query
13 Nov 2003
Manchester
Hi All
I am working on a search box that searches the db by keywords and manufacturer name.
Now I can have got that to work, my problem however is adding the option to search by all manufacturers.
Is there a value that I can submit via the form to show records from all manufacturers.
this is my query
Code:
SELECT *
FROM productquery
WHERE manu_name LIKE '%MMColParam2%' and smalldes LIKE '%MMColParam%'
ORDER BY currentprice DESC
Im guessing I will end up having to use some fancy show if kind of stuff
Thanks
Aaron
Code:
string MyQuery = "";
if (combo.text == "ALL")
    MyQuery = "SELECT * FROM productquery WHERE smalldes LIKE '%MMColParam%' ORDER BY currentprice DESC"
else
    MyQuery = "SELECT * FROM productquery WHERE manu_name LIKE '%MMColParam2%' and smalldes LIKE '%MMColParam%' ORDER BY currentprice DESC"
Something along those lines should do the trick.
TrUz
Cheers guys
This is how I did it in the end
Code:
Dim products
Dim products_numRows
Set products = Server.CreateObject("ADODB.Recordset")
products.ActiveConnection = MM_wizarddata_STRING
If Request.QueryString("manu_name") = "showall" Then
products.Source = "SELECT *  FROM productquery  WHERE fulldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%'  or smalldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%' or manu_name LIKE '%" + Replace(products__MMColParam, "'", "''") + "%' ORDER BY currentprice DESC"
Else
products.Source = "SELECT * FROM productquery  WHERE manu_name LIKE '%" + Replace(products__MMColParam2, "'", "''") + "%' and fulldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%' and smalldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%'ORDER BY currentprice DESC"
End If
products.CursorType = 0
products.CursorLocation = 2
products.LockType = 1
products.Open()
products_numRows = 0
However, now that i have it working another problem has surfaced.
I want to be able to search by manufacturer and keyword. So If a record matches both the manufacturer and the keyword then it is displayed. So I thought something like this would do it
Code:
"SELECT * FROM productquery  WHERE manu_name LIKE '%" + Replace(products__MMColParam2, "'", "''") + "%' and fulldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%' or smalldes LIKE '%" + Replace(products__MMColParam, "'", "''") + "%'ORDER BY currentprice DESC"
However, the use of the last 'or' statement seems to make it come up with records from all manufacturers. Is there a way of splitting the query, so it looks for all the ones that match the manufacturer and that have an instance of the keywords, in any one of the 4 fields that they could be in.
Sounds rather scary to me lol
Any help is greatly appreciated
Thanks
Aaron
