Can anyone help with an external X-FI XMOD problem
22 Nov 2002
Liverpool
Hi, i have had this X-FI xmod external sound card for a few months now without any problem, i do a lot of editing in sound forge which also has never been a problem, i noticed on the suppoprt site that a new firmware was availible; Creative Xmod Firmware 1.8.070516
which, i downloaded and installed, but since, sound forge just tells me i have no sound device connected and wont play any tracks, and when i click play i get a msg saing 'does not support 44,100 Hz at 16 bits'. although winamp and media player still seem ok at playing files, i also dont seem to have any user interface on my pc for the xmod, does anyone know if this is right or do you just use the controls on the xmod, i have also found even the vol slider on the xmod doesn't turn the vol up / down now either.
Am not sure if there are any other drivers for this but currently the driver used is a microsoft one which is dated 1/7/2001 and shows in the device manager as usb audio device.
any help would be appreciated.
James
