Everything has been running reasonably ok with my system but I noticed my Aida64 Memory cache write benchmark is two-thirds of what it should be. I have spent days trying to figure this out without success, trying various overclocks, stock settings, memory timings and getting nowhere. You can see from the screenshots below that the write bandwidth is 59,000MB/S and I believe it should be in excess of 90,000MB/S. I have run memory stress tests without errors.
Motherboard is Asus B650E-E Rog Strix
The ram is 64gb Gskill 6000 cl30 (F5-6000J3040G32GX2-TZ5NR Trident Z5 Neo RGB DDR5-6000 CL30-40-40-96 1.40V 64GB (2x32GB) AMD EXPO)
The pic below it is overclocked to 6400Mhz, but this is irrelevant since at stock 6000mhz the scores are even worse and the write speed is only 44,000Mhz
Can anyone suggest a solution please?
