Can anyone help with this little vista/monitor issue?
7 Jun 2003
Gloucestershire
Right before you say it, ive tried google and it hasnt helped, perhaps theres a way of using the same driver on vista but i thought id ask you lot...
NEC FE1250+ CRT, can run 100hz in 1280x1024 but vista will only allow me to select up to 85hz so i have to untick the little box (im sure you know what im on about), obviously this isnt a problem UNTIL it comes to games
i can still only select a max of 85hz when i get the option in games, if anyone knows of a way of using the XP drivers on vista then that'd be nice, if not anyone know of any vista ones because i cant find any for the life of me
Cheers for any help :)
