- 22 Oct 2020
I am looking for a case to replace my corsair 750d. Could really use some advice as randomly browsing for cases these days is a pain.
My requirements.
My requirements.
- It needs to fit a Corsair H115i Pro AIO with a 240mm radiator (315mm x 143mm x 54mm.) Preferably top mount but front or back mount also acceptable if I can mount fans on top to vent.
- My motherboard is the ROG Maximus XI Hero. Has 2 large heatsinks on the VRM at top of motherboard.
- It has to have at least 1 external 5¼ bays. Preferably 2. Or a built in USB 3.2 and 3.1 plugs and a card reader.
- 4 internal 3½ bays. + 2 2½ bays.
- Big enough to fit the new Strix 3080 OC at 318.5mm (When I get my pre-order
). - I also want a glass or perspex side. I am not into RGB but have set the CPU block to change with temperature and also like to see the QR code LCD on the motherboard.
