- 28 May 2004
- Cardiff
Hi, I've recently upgraded from a Athlon XP Mobile based system. As I've changed to a Core 2 Duo, pretty much everything has been replaced, HDDs, graphics card and so on. Its all reasonable stuff, with plenty of life left in it.
Rather than add it to my growing pile of old computer bits, I would like to use it as a Media Center PC or at least as close to one as I can get.
Its using a full size ATX Abit motherboard. Can anyone recommend a case which will accomodate this which is a) fairly attractive b) more compact than a typical midi tower case c) cheap-ish (£50 ex PSU tops I'd say) d) has good thermal properties without excessive numbers of fans
It doesn't have to look like a home cinema amp or anything like that. But the smaller the better
Cheers
Cheers
That looks lovely. So tempting. If I had the room I'd grab a 630 too.
