Can anyone recommend cheap single top box
23 Aug 2007
I use the Ryde 52L one from Amazon and from the looks of it, it's exactly the same one as the Oxford one which I assume is just rebranded.
The Renntec one looks very similar to my Ryde one, just smaller & even has the same oddly shaped key so it'll be OK and will get the job done but at that size branded ones aren't too much more expensive, £50 quid will get you a Givi, Kappa or Coocase top box if you really want quality.
Thanks Stovepipes that is a good price but really need it to be single size do to other stuff on the bike.
I think I will go with the renntec one it can't be too bad and I think my options very limited for cheap and small.
Thanks.
Thanks.
The Renntec will be fine. Might have to mod it a bit to get the mounting plate to fit your rack but it's plastic so it's easy.
Silly question but what's the other stuff a bigger box prevents you from doing?:confused:
Thanks and also got a gunboot hard case on the side sometimes as well.
Need to adjust it abit so it be some height as topbox at the back so it's not sticking out the back end to much like it is now.
