I am after one that works using radio or bluetooth as my computer is in the study and I am running a cable from this computer to a TV in the lounge and want to use a keyboard and mouse in this lounge. The computer in the study is located at about 3 meters from a wall which is not too thick and the door is always open and just around the corner is my lounge which doors are always open. So I hope with that information you could recommend me a setup where the signal will reach?
Also I am looking to buy the Speed Link SL-6399 Media Centre Remote Control and as it uses infrared. Unfortunately the infrared receivers USB cable is a bit short, is there a way to extend the cable? Are there USB extender cables?
Many thanks in advance
