Can anyone see a problem with this . .
18 Oct 2002
North Yorkshire
Hi
I have in my garage some old water blocks one from a Pentium 4 (socket 478 I believe) and the other from a Athlon Barton Socket A
Anyhow, what I was thinking of doing is, using some 2.5mm aluminium plate, make a top cover that will screw onto the top of the block (on top of the original acrylic top plate) with holes to allow it to mount to a 1150 socket.
After a little Google (and iv not had hands on the parts to compare sizes) but a I5 is roughly 1.48 x 1.48 inches, the p4 is 1.38 x 1.38 and socket A is 2.06 x 2.06 inches.
So, I am thinking, once I get the bits in my hands, and so long as the water block more than covers the heat spreader on the I5 and I make a plate for the top of the block with the correct holes in there shouldn't be a problem?
any thoughts?
Jason.
It would work but performance wouldn't be as good as a newer block, plus you would have to run coolant with corrosion inhibitor to stop the aluminium causing issues.
It'll work fine. Best check the old blocks are copper. There's no reason to have the aluminium plate in the water path so that's a non-issue
the aluminium wouldnt be in contact with the water, it would just sit on the top face and allow me to mount it into the "new" holes.
I dont think it would be a very hard job to be fair, and it will be a little different :)
on the performance side, my train of thought is that these blocks were for older, higher wattage CPUs, so it should handle a "cooler" i5. or am I off of the facts?
Jason.
