Can anyone suggest a good air cooler for Ryzen 5800x
7 Oct 2015
Haven't used air cooling since the Pentium days so can anyone suggest an air cooler to go with a 5800x?
Specs of the build consist of:
Asus Crosshair VIII Impact mobo
GSkill Trident Z Royals
Ryzen 5800x
Ideally looking for less than £35, though cheaper the better. Considering AMD do not provide a stock cooler with their CPU, this is only temporary solution while i make sure the components i have purchased work.
Would be a pain if some parts were DOA and the watercooling loop was in place.
Thanks
P.s i do have a EK Supremacy WB lying about which includes AMD fittings... the manual mentions AM3, so i assume the placements are different to AM4, or would the mounting bracket not matter?
ignore what i said.. answered my own question ha
Thanks to its small footprint, a collision with RAM bars is almost impossible and a backplate increases the stability of the CPU cooler. With the Freezer 34 , Arctic has again created a very efficient and extremely quiet CPU cooler with high compatibility.
