can gfx cards use YCbCr?
That doesnt make sense???
Your monitor can adjust your colours, and the software supplied within your gfx drivers can adjust colours. I might be being really thick, I cant see what youre asking
i mean if you hooked the gfx card to a tv using hdmi can you select YCbCr as all dvds and blu-rays are YCbCr and not RGB
as with the ps3 you can have RGB or YCbCr, i have my ps3 and denon blu-ray set to YCbCr and was wanting to know if you can do this with all the latest gfx cards
Yep, my 4890 supports YCbCr over HDMI.
Thanks for that good to know, but one question what is this pixel format option as I see there is a couple of options for that.
Do you use thissetting on your tv ?
