- 5 Jan 2004
- Wiltshire
I recently got one of the 3070 from the forum deals and upgraded from 1080ti and I think the 3070 has been causing strange issues. Strange because they are not normally related to GPU. Mostly file related issues and missing files. Although sometimes games just crash to desktop. Always the same games, others are fine. Occasionally blue screen on boot up - winload.exe missing.
Normally you would expect this to be RAM or HDD or maybe CPU related. However, benches run ok. Prime, cinebench memtest all ok. It seems that once loaded, things works. It's the opening and loading stuff that causes the problem.
I have tried different SSD for OS and different RAM and the problem still persisted - admittedly it's quite intermittent so difficult to troubleshoot. I was playing games last night no problem, yet it bluescreened this morning and wouldn't even boot. I must have spent 30 hours in the past few days troubleshooting - latest BIOS, New OS on different drive, different RAM.
I have had the 1080ti back in a couple of times just to see but it doesn't seem right to me that it's caused by the GPU, so have swapped it back to 3070 once things appear to be stable. Only for it to fail again later. I'm currently on the 1080ti again and cant cause any issues at all. Even running prime and 3D mark together or cinebench and superposition together is ok. Will give the 1080ti a good innings this time.
I was convinced it was a RAM or SSD issue but the faults have continued with replaced parts. Maybe it is mobo/cpu/BIOS but I dont have alternative spare parts to test that. Anyhow memtest and prime seem ok.
Rest of system is:
Ryzen 2700
B450I Auros wifi miniITX
16GB GSkill 3200
Corsair SF750
Everything is at stock and PSU volts seem fine.
Can it be GPU related?
How to RMA it when it runs and benches fine? (most of the time)
Rest of system is:
Ryzen 2700
16GB GSkill 3200
Corsair SF750
