Can i add a 2nd M2 drive?
1 Dec 2005
Stoke on Trent
Running an X570 TUF as per my sig.
Got a 250Gb NVME WD blue drive in slot 2 ( the one with the heatsink cover on it ). This is the one with windows on it
Im looking to add another 2Tb NVME drive - probably this one as its cheap atm
Crucial P3 2TB M.2 2280 PCI-e 3.0 NVMe Solid State Drive​
All it will be used for is running games off.
Will this setup work ok? It wont steal any bandwith from the GFX card will it?
I do have a PCIE Xfi in there as well but i will probably remove this when i open the case up again.
Can you state the exact model name (there are several TUF X570 boards)?
As far as I can see, the TUF X570-PLUS has no restrictions or conflicts between the M.2 slots and PCI-E slots.
I'd advise against the P3 though (it is QLC-based), unless it is exceedingly cheap. The 2TB version has only 440 TBW, compared to nearly 3x the endurance (1,200 TBW) on the WD SN770.
