Can i add a side window to this Lian Li case
If you can afford a £300+ case I think you could probably stretch to getting it modded for you. Plenty of laser cutting places that will do it for £30-£60 depending on the complexity of it :)
Of course, you could always try yourself but with a case that expensive I wouln't personally, not without a lot of practice.
+1, Just do that, personally i would mod it myself, it really isn't that hard to drill some holes, cut metal, use masking tape, sanding blocks and so on to get a nice finish, it's just if you can be bothered and have the time/want to put the effort in.
