Can I build a decent base for less than £150?
25 Apr 2007
London
I'm after a basic setup that can play games like Counter Strike Source and alike games. Do you guys think I can build the base for less than £150?
This is the best I could do which is a bit over my budget:
Motherboard
A decent one (any suggestions?) - £35
Processor
Intel Celeron E1400 2.0Ghz Dual-Core Processor (LGA775) - £34
Memory
Corsair 2GB (2x1GB) DDR2 Value Select PC2-4200C5 Dual Channel (VS2GBKIT533D2) - £23
Graphic Card
Asus GeForce 9400 GT 1024MB - £34
Hard Drive
Hitachi Deskstar 7K1000.B 320GB - £32
Decent Case & Optical Driver
Sony Optiarc AD-7240S 24x DVD±RW SATA Dual Layer ReWriter -£19
Case - £20
Total - £197
Any suggestions would be highly appreciated
Thanks
Gigabyte GA-EG41MF-US2H Intel G41
http://www.overclockers.co.uk/showproduct.php?prodid=MB-218-GI
Intel Celeron E1400 2.0Ghz Dual-Core Processor (will overclock to 3Ghz)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-225-IN
OCZ StealthXStream 400w
http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-OC
Hitachi Deskstar 7K1000.B 320GB SATA-II 16MB Cache
http://www.overclockers.co.uk/showproduct.php?prodid=HD-051-HI
Corsair Value Select 2GB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-097-CS
Asus TA-861 Midi-ATX Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-045-AS
http://www.overclockers.co.uk/showproduct.php?prodid=CD-038-OT
£220.10
£191.39 ex VAT
As cheep as your going to get!.
I dont know how the Intel X4500 graphics will run games (probly realy baddly)
£150 impossible new, second hand easy
£200 pile of SH***
£250 the spec below, Good branded parts, good performance & easly upgradable.
Asus M4A785TD-M Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard
AMD Athlon II X2 Dual Core 240 2.8GHz (Socket AM3)
Corsair CX 400W ATX Power Supply
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM
OCZ Intel Titanium XMP 2GB (2x1GB) DDR3 PC3-12800C7
Coolermaster Elite 335 Case - Black
Total £248.94
edit ohh go steal an opitcal or something lol
You could build a system that will run XP or Vista/7 with the features turned off.
Will it be any good? Probably not. Might be better off just getting a netbook. Everytime I see a Celeron being used I die a little inside.
Buy a 2nd hand rig, with a reasonable graphics card, something like a 6600GT or Radeon x800, something that really wont cut todays games, but is still fine for earlier DX8-9 stuff.
Cant see any way you can possibly shave another £50 off that build, and if you dont have a dedicated GFx card it really wont run CS:Source playably.
Eg: Some live adverts I found:
Full pc setup 1.8cpu 512 memory 40 gighd 128mg geforce 5500 gfx keyboard mouse monitors and speakers brilliant pc pretty fast bargain £35
Pc for Sale Full Setup, Athlon 2Ghz, 512mb Ram, 256mb Graphics, 100gb Harddrive, Monitor, Keyboard, Mouse and Speakers. Windows xp, tv Card to watch tv. £80
^ Something like that, depends whats local. Add an OK AGP card off ebay, and your'e reasonably sorted.
