can i connect case fans on to a fan controller using a 3 pin or 4pin splitter?
11 Jul 2010
ENgland, Oxford
I want to know can i connect two case fans, to a 3 or 4 pin splitter so when i connect that splitter to my fan controller it will control both of the fans,
the fan controller only has 4 slots and i will be using 6 fans and 3 of them will be outake so i can just use splitters to control the outake ones
Why don't you connect the output fans to be alwyas on? So you have permanent hot air exhaust from the case using simple throughput molex connections.
Strange, no one seemed to jump on this thread and request you reprove you are qualified in some way.
