Can I connect more than one fan?
Can I connect more than one fan (2 manbe 3 fans) to each fan header on the mobo? Has it got enough juice?
Yes. The Intel standard requires each motherboard header to be able to provide 1.2A at 12V (14.4W). Your fan should have a current or wattage figure written on it eg. Yate Loon fans are usually rated at something like 0.38A at 12V so you could attach 3 of those.
Arctic Cooling PWM fans can be daisy-chained upto 5 per 4-pin header, so that may be a better solution, especially if you have a Gigabyte motherboard with lots of 4-pin connectors.
