Can I connect up a Hi-Fi sound system to my computer?
21 Nov 2002
a
Say I was to buy an amp and some speakers could I hook it up to my PC? Basically because I want to get a LOUD LOUD sound system for my computer, but from what I can tell Hi-Fi speakers are better and more cost-efficient so I'd be better off getting them?
Thanks in advance.
Hi-fi speakers can go loud, but you're getting quality rather than out and out volume with them most of the time. Saying that, even the most modest bookshelf speakers that I've owned (mission m72) were plenty loud enough.
If you want music, then definitely get a stereo amp and speakers. You can hook it up by using a headphone jack to 2 x phono converter cable, easily purchased from any high street electrical store or from the interweb.
As far as what speakers and amp to get, definitely only look at stereo solutions, as surround sound will eat up your budget if you're looking at separates. There's always the floorstanders vs bookshelf debate, which does depend on your budget and the size of your room. Are you looking into the second hand market? You can get some serious bargains and really increase the quality of gear that you can get. I would have paid double the price for my system (if not more) if I had bought everything new, but the sound quality certainly hasn't decreased over that time noticeably, and it definitely hasn't degraded by half.
In summary, yes you can connect your hi-fi to your computer. Have you got a sound card? This does make a difference, and after some new memory it's definitely on my list of upgrades. My CD player is much better anyway for serious listening, but it would eliminate a lot of needless electrical interference which is very noticeable.
Thanks for the extensive reply, the second hand market might work to be honest, as I'm sure you can pick up some bargains. My room isn't massive but I could probably I could find some room for floorstanders. Would it be worth getting them over bookshelf? I have a rubbish sound card for my computer, so I'll definitely pick up a new one, been looking at
Creative Sound Blaster X-Fi Xtreme Music - OEM (SC-043-CL)
http://www.overclockers.co.uk/acatalog/Creative_Sound_Cards.html
How good is that?
Cheers
For stereo use, you might be better off with a quality stereo card like the M-Audio AUDIOPHILE 2496, available for £55 from a competitor (may also be available second hand). I'm sure it will give better quality, but may be more difficult to setup, worth thinking about anyhow. It uses phono outputs, so a standard Hi-Fi interconnect would provide the connection.
Floorstanders in a small room can sound very boomy with overblown bass. I'm probably on the very lower limit for my particular speakers with my room size at the moment.
