Whilst I know remote desktop is an option, there are certain times when I would just like to be able to control either of my 2 pcs with my MS Wireless Keyboard and Mouse combo...
The wirless control unit connects to my pc via 1 usb and 1 PS2 port. Previously when I used wired devices, I have a 2 pc KVM which worked fine.. is there a similar device I could use that would enable the use of my wirelss combo...??
Would a simple KVM Switch that would allow the connection of the 1 usb and 1 PS2 input suffice, or as they are wireless, would there be more to it...??
The only thing I can think of, is that there would be a delay in be able to use the evices while the wirelss signal re-established itself due to the mementary loss of power during the switchover...
Anyone know...???
Thanks
Anyone know...???
Thanks
