- 11 Oct 2005
- Derbyshire
Hi I have a external HD x 1TB in fat32 format as I used to use it with my PS3
It is 80% full of data.
Can I change it to NTFS without (MOST IMPORTANTLY) loosing any of my data presently on as fat32?
reason being. I need to transfer files that are larger than the 4GB limit fat32 allows. (MKV's)
Or is there anything that will cut MKV's down into a couple of parts....... and is there any benefit being NTFS compared to Fat32?
thanks
thanks
