Can I downgrade the KHX1600C9AD3B1/2G to 1.5v, without problems or is it already at that speed?
Status
Not open for further replies.
26 Feb 2012
I need to buy some new ram but only 2GB and the brand I have currently only does a minimum of 4GB (this is the RAM set I currently have http://www.****.co.uk/Products/Comp...DDR3+SDRAM+CAS+9-9-9-24+1.5V+?productId=44336). The only difference between this RAM and the one I have is the voltage as it says in most place it runs at 1.65v (I have compared CAS latency, Non-ECC, clock speed). However it displays this on the kingston website but if you open the pdf ( http://www.kingston.com/datasheets/KHX1600C9AD3B1_2G.pdf ) it shows it as 1.5v. Now I am not into depth in computer components so could someone make sense of this as I am quite confused. Also I am not sure if this is important but it says my current RAM is PC3-12800 and I am not sure if it is or needs to be the same with the extra RAM.
Status
