Yeah, i was thinking bout bending those pipes a little.
But this guy seems to have done it in the same thread:
Quote:
Originally Posted by Dew itt right
The SB doesn't get nearly as warm as the NB anyway. Plus what little heat it does put out, the 680i's heatpipe setup puts the SB heat onto the NB before dissipating.
Absolutely incorrect... the MCP is the southbridge. Check under BIOS and you'll find out that it DOES get blazing hot.
Also your 680i southbridge HR-05 mounts different than I had mine. I had two HR-05 SLIs on my 680i, and fit SLI 8800GTX also. Just couldn't fit an XFI along with them.
