13 Jan 2007 at 10:06 #1 Jimbo Jimbo Soldato Joined 18 Oct 2002 Posts 6,906 Location Newcastle, England I have a 256mb usb pen drive, would I be able to flash my bios using this? I flash in dos using afudos, would it work? Allways used floppys in the past. But I dont have one connected to the motherboard.
13 Jan 2007 at 10:37 #2 f666 f666 Associate Joined 19 Dec 2004 Posts 1,132 Location Cheshire you can if your board has usb support whilst in dos if you use a boot cdrom made in nero or ultimate boot disk it should tell you as you boot you could also use a cdrom
13 Jan 2007 at 10:42 #3 Jimbo Jimbo Soldato OP Joined 18 Oct 2002 Posts 6,906 Location Newcastle, England Cheers, I'll give it a shot.
13 Jan 2007 at 11:04 #4 Jimbo Jimbo Soldato OP Joined 18 Oct 2002 Posts 6,906 Location Newcastle, England Got a problem, I havent a way to get into dos, cos my boot disks are floppys lol. I'll try your method above using a bootable CDRW.
13 Jan 2007 at 13:54 #5 cuke2u cuke2u Soldato Joined 27 Feb 2006 Posts 5,239 Location Lincolnshire Hi, I've flashed mine a couple of times using a usb memory stick and the utility within the bios... ChrisC
13 Jan 2007 at 14:46 #6 The Running Man The Running Man Caporegime Joined 18 Oct 2002 Posts 37,804 Location block 16, cell 12 ive flashed my last 2 mobo's multiple times from inside windows and never had a prob..
