Can I get a 'vanilla' copy of W7 using credentials from my Packard Bell OEM?
31 Aug 2009
Surrey, UK
I bought a Packard Bell mini tower a few years back, cannibalised pretty much all of it by now; however I still use the version of 64bit W7 which came embedded on its hard drive.
The Packard Bell OEM version is awful: it uses a backup creator designed for Acer laptops and can only burn onto CDRs, taking up 3 discs; it comes with 100s of MBs worth of forceware and about twenty 3rd party games all of which, as I'm a purist, I just uninstall.
I'm building a new rig soon and would like a fresh, 'vanilla' install of W7 with no Packard Bell rubbish. However I'd rather not pay the £80 for a new version of what I essentially already have. Is it possible to use serial numbers or credentials within the Packard Bell version to request/download a vanilla W7 direct from Microsoft?
I'm not really comfortable downloading it for free from a random forum.
Its actually a popular tech-talk website.
I've downloaded the ISO from there before, it's a direct download, no torrents, and if you are really that worried scan it before you download it.
Do you download the ISO and then after installing have to validate using a serial code? So it's still 'legit'?
I always thought OEM died with the original hardware and was not transferable - have things changed?
(From a technical licensing point of view of course)
You're correct.
OP:
The Windows 7 licence that came with your Packard Bell desktop is OEM, meaning it dies with the computer (Defined as the motherboard.) Therefore you will need to buy a new OEM or Retail Windows 7 :).
If you're building a new rig surely you can afford to pay £80 for the most important part, the software that operates it?
:confused:
You're correct.
OP:
:confused:
Well of course. My point though was that I'd rather not pay if I don't have to.
I've changed the mobo since buying the Packard Bell and the OS swapped over fine, didn't need to reactivate or anything. I want to do a fresh install with the new rig (I'm actually keep the HDD this install is on), I just don't want the Packard Bell forceware.
For the sake of purity I may just buy a retail copy of W7. At least that way I'm sorted forever.
A retail copy is a good investment :).
FYI I've reformatted loads of branded laptops with "vanilla" OS disks and never had a problem activating the installs using the keys on the COA :).
