can i have a duo
I was able to find this....
CPU Support
* Intel Pentium D Dual Core Technology
* Intel® Pentium® Hyper-Threading Technology (HT Technology) with FMB Performance 2005 support
* Intel® Pentium® 4 processor in an LGA775 socket with an 800 MHz system bus, 2.8Ghz to 3.8 GHz or higher
* Intel® Celeron® (D) processor in an LGA775 socket with a 533 MHz system bus, 2.8 GHz or higher
(just do a Google)
It does suggest that you will be limited to a P4
It seem that it is a Packard Bell Rio motherboard - possibly made by Gigabyte..???
EDIT :
http://support.packardbell.com/uk/item/index.php?i=spec_Rio&ppn=PB34316801
http://itcity.com.ua/?itemid=92858
But it will take a Pentium D according to the info posted by Vimes so a 945 (2 x 3.4GHz) should work. Make sure your cooling is as good as it can be as I expect a 945 will get toasty.....
