can i have a pci sound card, AND functional front panel audio connectors?
Caporegime
29 Jul 2011
In acme's chair.
I want to get a cheap(ish) sound card soon, probably an audigy or a xonar, to escape the horror of realtek 'hd' audio.
If I connect up the sound card with my 2.1 speaker system hooked up, will the front panel audio connectors become non-functional due to the different default sound device?
I use the front connectors for my headset :(
*edit* its not for the system below, I need to update the sig. :D
As long as the card has a FP header, then it will be ok, you would need to disconnect from the motherboard and plug it into the card. My Xonar D2X does not have one (much to my surprise!).
