Can I improve my case cooling? Or is it good enough as is?
7 Nov 2015
Hi, I'm planning on putting an i9 12900ks (not overclocked) on an asus z690-g board cooled with a noctua nhd15s inside a corsair 7000d airflow. Currently my plan is to have three 140mm fans as intake in the front with one 140mm fan as rear exhaust. Also I will put a 3090ti in there as well.
I would like to save the extra bit of money and not have more fans as top exhausts but I will if need be. What are your recommendations for cooling in this circumstance? Is it good enough?
Any advice appreciated.
Thanks
I’ve preferred the legit push pull fan configurations. Just optimise cable management and allow air from the front and exit at the rear. The Noctua tower will help in this setup.
