LOL............ThanksSlam62 said:course you can my luvver!!
Yes microsoft only give you one key and two DVD's (32bit & 64bit) in the ultimate full retail edition...Jokester said:Is it definitely the same key? My Home Premium 64 key is different to the 32bit version.
Jokester
chaparral said:Yes microsoft only give you one key and two DVD's (32bit & 64bit) in the ultimate full retail edition...
Jokester
Ronaldo said:where did the 64bit key come from? MS with the disk?
Jokester said:Yeah, you provide your 32bit key to MS and they give you the 64bit disc with a new key.
Jokester
Ronaldo said:I didnt get a key with my 64bit DVD when i ordered it from MS, where was the key on the note or disk?
I'm always losin me keysJokester said:![]()
Oh wait you're right, it does use the same key. I've just got the one stuck inside my box.
Jokester
You most probably can.gareth170 said:well u can't install both 32bit & 64bit and dual boot between them using the same key...
csmager said:You most probably can.
If you can dual boot two 32-bit installations, you can dual boot between a 32-bit and a 64-bit. Should activate fine, as they're both the same PC. And you're only using one at once.
Presumably that's to stop you installing one of each on two PCs. You could dual boot XP with XP, so you can dual boot Vista with Vista. It's completely possible, and there is no difference between 32 and 64-bit - especially in the eyes of the activation servers.gareth170 said:it even says on microsoft site u can only install and activate ether one .
