Can I legitimately / legally run OSX in a virtual machine?
Status
Not open for further replies.
22 Dec 2008
England
What I've been able to find online suggests "no".
I write code. It's really useful to push the code to a build server which runs a series of tests on it. Buying a dozen servers is a bit extreme, so I tend to test on a number of virtual machines. Windows and various *nix derivatives.
I now have a shiny new macbook and am considering adding OSX to the supported environments. For that to be viable, I need an OSX build server - all it has to do is compile and run a load of C and Fortran periodically.
Buying a license is fine but doesn't seem to be sufficient to let me install OSX on non-Apple hardware. Buying a license and then installing a slightly shady hacked copy doesn't seem ideal. Am I missing something here?
The OSX license only allows you to run it on Apple branded hardware. If you want to virtualise it you have to do it on your macbook.
Status
