can i lower my timings?
Man of Honour
9 Jan 2010
Try it and find out?
Worst that can happen is that your OC will just reset. There might be a difference but I doubt you'd notice it in any real world applications, gaming, photoshop processing etc.
you'll see very little real world difference, but that shouldnt stop you from having a tinker.
it might go lower, it might refuse to post, luck of the draw!
hmm, tried it at 6-6-6-17 & 6-6-6-18 and computer says no :/
if i ran it at 1804mhz and it didnt like it would it also just fail to post? i dont want it to work but be too hot and end up damaging it
XMS3 is good quality RAM, 1800MHz should be achievable quite easily, just loosen the timings and test.
