H100i works fine vertically, just try to place the top of the radiator higher than the pump and pipe entry to radiator at the bottom, this will allow any air/cavitation in the system to accumulate at the top of the radiator away from the pump
Thanks for the responses guys but I didn't bother to check if the tubes would reach the front fan mounts- turns out they can't so I'm dropping the vertical front mounted idea!
