Can I plug a PCI Express 1x or 4x card into a PCI Express 16x slot?
1 Nov 2007
England
I'm thinking about getting a sound card for my compurer but I'm pretty sure I only have a PCI-Express x16 slot free. Can I just plug a x1, x4 or x8 PCI-Express card into a x16 slot or do I need some sort of converter for it?
You may need to adjust a setting in the bios to get it running properly so that it doesn't disable another slot or slow it down.
My Asus Z77V for example has options to disable a sata port if using the third x16 lane in this way or it'll reduce the second x16 (x8) slot to x4 (I think... Been a while since I looked at it).
