can i push it more
30 Nov 2005
have 3200 winnie running like this
250fsb x 4HTTx 10 = 2500 vcore 1.525
can get post at 2600 what can i do to get to stable at 2600mhz
Try lowering the HTT to 3x, increasing the chipset voltage by 0.1v and lowering the ram speed (166 if it is 200, 133 if 166)
Mmeory speed makes very little diference for athlon 64s, the only thing that might get worse is your super pi results.
You could just try pushing it and make sure the ram can take the higher speeds, or increase the rams timings to allow for a higher clock
